View all releases
Adam Listek
January 07, 2026
It’s 2 a.m., and your helpdesk lights up: no one can sign in because your identity provider (IdP) is experiencing an outage. Maybe it’s an Entra ID outage. Perhaps the domain controllers are down due to a recent patch. Either way, your operations team still needs access to resolve the incident. This is precisely why emergency login code authentication exists in Devolutions Server (DVLS): a secure and auditable method for designated administrators to gain access even when identity providers are unavailable.
When enabled globally and for designated users, the emergency login code option adds a controlled “break-glass” path right on the DVLS sign-in page. Administrators with authorized access can request a one-time code, receive it by email, and use it to authenticate without relying on your IdP during the outage window. The event is recorded in DVLS audit logs and triggers an administrative notification, ensuring governance is preserved while the service is restored.
A working SMTP email server is mandatory to request and receive emergency codes. Verify under DVLS Administration → Server settings → Email before you need it.
The rollout process is straightforward and aligns with least-privilege practices. Best practices recommend keeping the list of users small and ensuring reliable email delivery.
DVLS Administration → Server settings → Authentication and check Enable Emergency Code Authentication.
Each user must also have this enabled. Edit the user and, in the
Generalsection, checkEnable emergency login.
Emergency login code authentication gives you a provider-independent safety net. Whether you authenticate daily with Entra ID, Active Directory, Okta, or PingOne, your team retains a governed path into DVLS when the upstream identity providers falter.
Learn more about the tools available in Devolutions Server, or start a trial to discover how Devolutions Server acts as a powerful data source for Remote Desktop Manager.
