Thumbnail for Spotlight on: RDM CyberArk PVWA credential entry for PSM connection
RDM now supports CyberArk PSM connections via PVWA credentials and a new resolving mode, enabling secure, streamlined session launches without direct password retrieval.
Remote Desktop Manager (RDM) now supports a streamlined method to initiate Privileged Session Manager (PSM) connections using CyberArk PVWA credentials. This integration simplifies session launching by passing directly through CyberArk PSM, making it easier for users to connect to PSM-protected resources.
Click here to see how Remote Desktop Manager and CyberArk work better together.
Using the new PSM connection resolving mode
The CyberArk PVWA credential entry in RDM now includes a new Resolving mode option:
  • Credential injection (default): Uses CyberArk to retrieve credentials and inject them into the session but is a direct connection to the endpoint (not going through PSM).
  • PSM connection: Launches the session through PSM, and the PSM server handles the authentication.
This change ensures that users can leverage PSM without requiring password retrieval, addressing concerns about CyberArk policies such as DisableCyberArkPasswordRetrieval. This means that even if that policy is enabled, sessions can still launch since credentials are not retrieved directly. As the connection is established via PSM, all actions are recorded in accordance with policies in CyberArk.
For this example, we are going to create a CyberArk PVWA entry in RDM, link it to an RDP session, and then connect easily through a single action.
  1. Add a new credential entry in RDM.
  2. Choose CyberArk PVWA as the credential type.
  3. In the Resolving mode dropdown, select PSM Connection.
CyberArk PVWA credential Resolving mode
  1. Create, or modify, an RDP session entry to link to the newly created CyberArk PVWA credential entry.
Link RDP session to CyberArk PVWA entry
  1. You’re all set! Start leveraging PSM in Remote Desktop Manager.
When a user starts the RDP session, RDM automatically resolves the CyberArk credentials. The session is routed through CyberArk’s PSM gateway before launching to ensure secure connectivity. Finally, the user is authenticated and connected without additional manual steps.
Launch RDP session using PVWA entry
Summary of business and user benefits
User value
  • Simplified session initiation: CyberArk PSM sessions are launched as easily as other RDM entries.
  • Consistency: PSM sessions behave like native RDM connections, reducing possible confusion or setbacks.
  • Improved efficiency: Multiple steps required in CyberArk’s dashboard are eliminated.
Business value
  • Enhanced security compliance: Ensures PSM adoption without workarounds.
  • Reduced training overhead: Easier for users to understand and use CyberArk PSM within RDM.
  • Operational consistency: Maintains a unified workflow across all supported session types.
Switch to the new PSM connection mode today!
The integration of CyberArk PVWA credential entries for PSM connections in RDM significantly streamline secure session management. By introducing the new PSM connection mode, RDM simplifies the connection process, ensuring sessions route securely through CyberArk’s gateway without direct credential retrieval. This enhancement not only improves user efficiency and experience but also strengthens organizational compliance and operational consistency. With RDM’s seamless CyberArk PSM integration, organizations can confidently enforce privileged access security without compromising productivity.
Already using the CyberArk module? Try the new SIA integration and tell us how it works for you—or what we can improve or contact us to get the CyberArk integration module.
Join the discussion and share your feedback in the comments section below or on our forum!
More from Products
